flyscreen pic's
mr hunt
Perth, WA
2013 Roadster
Purchased the fly/sports screen and mounts. All arrived safe, well packed and earlier than expected - all accept the fitting instructions.
Seems pretty straightforward and the bracket/bolt combo's are obvious.
If anyone can help, i would appreciate a close up pic of one of the fork brackets mounted on the bike and one of the screen/bracket just to be sure all is hunky dory.
Just loose mount the fork leg brackets and the others will be pretty easy to sort out mate. Sorry but I don't have any pics. The set-ups the same on any of the screens Triumph sells.
I do recall (got rid of mine years ago) that the mounts can go on 2 ways. One way they will touch up against the headlight bowl. Trial error should sort it.
Yeah one is touching the cowl but the others are clear. The only drama I have is the bolts for screen appear to be too long and domed nuts can't pull up far enough - about 3mm short and no more washers #scratching head#
That's looking like the most viable option. Triumph don't appear to be big on spring washers so nylocks it is.
Thanks fellas
http://www.triumphinstructions.com/ type in part number
Pics of mine.
I replaced the mounting bolts with stainless steel.
Check the paperwork, it has a web address http://www.triumphinstructions.com then put in the part number when prompted. I know because this is exactly what I did just yesterday.
BTW, it fits perfectly with all the standard fitments.
Thanks for the instructions link gents - I'll get on to it tomorrow when I retrieve the packaging from the recycling bin at work :thumbsup:
