Hey everyone,
I just finished flashing Ulf Penner's unrestricted map onto my 2023 Rocket 3 R Chrome, and I wanted to drop my experience here to help out anyone else who is on the fence or intimidated by the process.
First off, a massive thank you to Ulf Penner. What you’ve done for this platform is incredible.
The Verdict (The Ride):If I had to sum it up in one sentence:
The bike now feels exactly like you imagined it was going to feel when you first signed the papers at the dealership.
We all know that frustrating rubber-band feeling in 1st and 2nd gear where the factory throttle restrictions hold the bike back. That is completely gone. When you roll the throttle now, the engine snaps to attention instantly. It pulls exactly the way a 2.5L triple should pull—no hesitation, no artificial electronic wall. As a bonus, low-speed cruising through neighborhoods in 2nd and 3rd gear is noticeably smoother and way less jerky. It’s a completely different motorcycle.
My Setup:
- Bike: 2023 Rocket 3 R Chrome (Canadian market)
- Hardware: Samsung Galaxy Tab A11, OBDLink LX (plugs directly into the black 16-pin port under the seat—no adapter cables needed for the 2.5L!), and a NOCO Genius 10A charger.
- Software: TuneECU for Android
- The Map: USA-Rocket-3-RR-Black-from-VIN-AV5457Map-opti.hex (This map is awesome because it opens the ETV tables to 100% and optimizes the fueling, but leaves the factory 7,000 RPM redline intact so it's mechanically safe).
Step-by-Step (How I did it & The "Gotchas"):
There is a lot of scattered info out there, so here is the exact sequence that worked flawlessly for me without a single error code:
- Prep the Tablet: Make sure your Android device has Bluetooth on, Wi-Fi off (or Airplane mode on with BT enabled), and NO other apps running in the background. If you have the OBDLink app, force-close it so it doesn't fight TuneECU for the connection.
- Prep the Bike: Take the seat off, open the fuse box, and pull Fuse #2 (7.5A). This kills the headlights. Connect a good battery tender (my 10A NOCO held the bike perfectly steady at 12.5V+). This is mandatory—if voltage drops, the flash will fail.
- Save your Stock Map: You can't "read" the map off the 2.5L Keihin ECU. Connect to the bike, look at the bottom bar in TuneECU to see your factory Map ID (mine was 31255), then use the app to download that exact OEM file from the TuneECU server to save as your backup.
- Load the Penner Map: Open the Penner .hex file in TuneECU. Turn the bike's handlebar switch down to RUN (do not start the engine). Note: The fuel pump and stepper motors will whine/hum endlessly while the switch is in RUN—don't panic, this is normal.
- Flash: Hit ECU -> Connect, wait for the green light, then hit ECU -> Reprogram. Put the tablet down and don't touch anything. It takes about 20-25 minutes. The TFT dash will go dark and throw warnings—again, totally normal.
- The Golden Rule (DO NOT RESET ADAPTATIONS): When it hits 100%, TuneECU tells you to cycle the ignition. Turn the switch to OFF, wait 10 seconds, turn it back to RUN. Do NOT click Reset Adaptations. Since you didn't change physical parts, wiping the adaptations just forces a useless 15-minute idle relearn and risks throwing a crank sensor fault.
- Clean Up: Swipe over to the DTC screen in the app and hit Erase to clear any temporary communication codes that popped up while the ECU was offline. Hit Disconnect, turn the bike off, unplug the OBDLink, put Fuse #2 back in, and start it up!
(Note: Your fuel gauge will probably read empty right after the flash. It resets itself after a few minutes of riding. If your cruise control doesn't engage on the first ride, just pull over and manually squeeze the brakes, clutch, and push the throttle forward once to reset the safety switches).
Hopefully, this helps someone who is nervously staring at their tablet in the garage. Take your time, pull the headlight fuse, hook up a charger, and enjoy the beast this bike was always meant to be!
