Thank You Mr. Penner
Hello, this is how i've built serous power with the my 2020 R3.
It started with a Penner map tune, then I installed
Vandemon-Stealth E-Valve Titanium Slip-On Mufflers, headers and a DNA filter.
The Vandemon headers flow 14% more air, as you can see from the photos. Intake runners were polished.
I have installed a wideband O2 sensor in the Vandemon exhaust right after the header collector.
This was for fine tuning the fuel/air ratios.
Penner has done a great job with the map program, "Thank you Mr.Penner” .
I have the wideband O2 sensor connected to a Fueltech Nano-Pro controller used for monitoring O2 in the exhaust.
This controller has a data logger to review after each ride.
I have attached the specs on the exhaust system, and Headers,
Stealth E-Valve Titanium Slip-On Muffler, Production years: 2020-2022
  • O2 sensor provision M12x1.25
  • Power +54% Torque@2500rpm & +25% Hp@6760rpm
  • From 133hp to 165hp@6760rpm
  • From 120nm@2500rpm to 185nm@2500rpm
  • Peak Torque From 172nm@5380rpm to 200nm@3870rpm
  • Performance figures achieved after flash tune & DNA air filter
Triumph, Stainless steel exhaust manifold.
  • Exhaust Port I/D 15% larger than OEM
  • Discharge Port I/D 9% larger than OEM
This set-up, Significantly improves exhaust flow efficiency by creating a low-pressure area (mild venturi effect)
as exhaust gases pass each cylinder exhaust port.
This characteristic is essential for enhancing engine volumetric efficiency, something that the OEM 3-into-1 manifold cannot achieve.
This Performance eliminates all restrictions.
Im setting right at about 180HP and 190Lbs Ft of torque.
No drivability issues, and no check engine light……...
This Rocket, Likes to run. Like a raped ape
Total cost to date $4000.00
Rear tires every 3000 miles. 12,600 miles, and never ran better.
Exhaust experts/engine experts - I need your valuable inputs here
My 10second quarter mile run
Exhaust, headers and flange, All fabricated by myself, welds were cleaned afterwards and heat shields were also fabricated
Running 100% RICH with DNA air filter
the torque is insane now, mileage is basically non existent, Only getting 23 miles per gallon or 10 KM per Liter
I have real-time air fuel ratio monitoring system installed as well, cost $500usd
Realizing that the answer to this question is highly subjective, but how does the sound/volume compare to stock with the E-valve enabled vs. disabled? I would think so, but how much does that affect torque when changed between the two settings? Curious minds want to know....
Hello, Journeyman,
In stealth mode, it is as quiet as the stock mufflers. I have found this to be most useful on road trips when cruising around 3,000rpm. It's nice to
enjoy the ride and not listen to loud exhaust. I haven't noticed a real drop in performance in this mode, with the exception of how it revs.
Now in performance mode it has a deep authoritative presence when I get on it. I have been told it has a deep rumble, you know when I'm getting on it.
The engine revs to redline quickly as it pulls hard to 7,000rpm.
Push Button switch location, Left side.
This rotates the E-Valve 180-degs each push of the switch.
Nice install,Im impressed with how your finished exhaust turned out.
Would like to see dyno results between all the different collectors, would be interesting, would think each has a different number and effect.
Did you get the fuel numbers under control?
How do I find about more about the wideband sensors?
Wow that's a lot less loss than I expected, thanks for enlightening us.
OK so I've received my OBDLinkMX+ signed up to Tuneecu and reset my service light and checked a few parameters, so I know it is all working. I've been trying to find the Penner derestricted tune for my 2020 GT, but can only find the tunes to download on Tuneecu But they specify for stock exhaust and I have a decatted Zard, on mine and I'm not even sure if this is the Penner tune?
The Tune number is 31012-3 have I got the correct Penner tune please.
P.S. The bike is a UK bike.
Thanks in advance for your help, it's a bit of a learning curve for me.
Ade
I downloaded it from the app, but not even sure if it is a Penner Tune.😵‍💫
It's located in the custom maps folder (as seen above) and at the bottom it says this:
When you download it the name of the file is:
When you go to open the file that is the title you are looking to open.
When you open it in TuneECU it might only show just the map number 31012, not the full name above. As long as you tapped that file to open it should be the Penner tune. To verify that, go to ETV 3 in the open file and check the last column of numbers. They should all be 100. If the numbers near the top of the last column in ETV3 go down to about 76 then that is the stock factory tune.
If you downloaded the stock map from the 3 and 4 Cylinder folder it would look like this in the TuneECU site folder:
