sleeves
Nitrous
Hi All
Had a problem this week, typically it was as I headed off on holiday this, i should have left things alone but it got me to thinking.
For some reason I reset my TPS and stepper motor, checked my ECU map then accepted the trims on the PCV AT. I have the POD300 that displays AFR etc but took it off as I only have one mount and wanted this for the radar detector. On the day hopped on bike and off I went bike ran like a dog, hesitation on throttle, backfires, unstable at low revs. Plugged in my POD as I had it with me and bike was running very lean at low revs. Acceleration and load was fine. Once riding for a while the problem sort of went away but stop and start again it came back
I solved the whole issue by reloading Hanso's (The Legend) base PVC map he sent me and all was well.
So here's the question and how I think i got to this issue.
I'm running the Autotune and its targeting an AFR value that we set in the map and its making trims to the fuel injection that we accept and then make permanent. If I am riding long distances and the bike ECU is jumping between the F and L tables this is going to mess up the fueling correct? as the ECU will be changing its injector pulse timing but the PCV wont know this and applying its trim to it as its simply trying to get a set AFR on the O2 sensor.
Should I turn off the FL switch when running the AT so effectively there is only one table the AT works with?
