Eastern Beaver kit install
tekardi
.060 Over
Buenos Aires - Argentina
Today I received from Japan my kit, I was really surprise because it only took 10 days to be delivered down here but the problem is that I don t know how to install this and the instrucctions seem to be for more tech people ....as a lawyer I will need some pics to put this to work ....does any done this before thank you...remember my English is basic ...thank you all
I have some pictures in a thread somewhere. Give me a minute to find it and post a link.
Try this. Its the kit with the low on/off.
If you did not get that kit just disregard the switch.
  • Eastern Beaver Kit Diagram.pdf
Thank you very much but I am confuse in this fase....
I removed two cables from headlamps and install the new ones and now I have this ....take a look of the pictures
What must I reconnect !&@#$%%-? SHOULD I LEAVE ONE OF THE END OF THE ORIGINAL HARNES POP IN WITH THE CUT CABLES?
sorry I m a Lawyer !
What about the two position small lamps? Just forget them? What are the two blue conectors for? Thank you all for your patience but this for me is basic chinesse !
Enviado desde mi HTC_Flyer_P512_NA usando Tapatalk 2
Chose one of the two harnesses in the photo and use it to attach the 2 blue connectors. I plugged mine back in and cut the wires between it and the headlights.
Follow the instructions on wire colors and connections.
The black and yellow OEM wires are for the park lights. If you want to use them you will have splice the yellow OEM wires together and then the black together where they come from the lights then to one of the OEM harnesses.
The blue/white OEM wire to the Beaver kit connector with the white wire and the blue/red OEM to the Beaver kit connector with the yellow wire. The end of the blue connectors unscrew. Try one and you will see how it works.
Do I get free legal help for this?:D;)
Sorry I forgot to add that if you use both OEM harnesses you will have to tape up the ends of the wires that you are not using, real well. You dont want them to touch.
If you do not use the park lights then cover the second unused connector with electrical tape or something.
There are 2 connectors for EACH headlight, the H4 at the back of the bulb and the little connector that plugs into the wiring harness.
You use one of those little 4 pin connectors for BOTH headlights. You remove ALL the old wiring from the little connectors all the way to the head lights. The new wiriing replaces the need for more than one little 4 pin connector (that you are holding in the picture).
You cut one little 4 pin off a headlight loom (the wires that go to the headlight) BUT leave enough wire on that connector to strip some insulation off to connect to the barrel connectors in the EB kit.
What you are doing is replacing the stock wire setup for a similar setup that uses the handlebar controls and operates EXACTLY like Triumph intended (but managed to screw up). That little 4 pin connector is what will operate your lights, it powers the two relays that put battery power onto your headlights (which get a LOT brighter).
So you will need ONE little 4 pin connector from the original setup, and NOTHING else.
If you want to keep the position lights (the little bulbs in the reflector) wire those up to the yellow and black wires on the little connector.
Understood
Ok so from the wiring I remove I ll cut one end with some inches to connect to the new kit, I ll not install the park lights as I think there are not usefull and that s all thank you all ! :D
ok so from the wiring i remove i ll cut one end with some inches to connect to the new kit, i ll not install the park lights as i think there are not usefull and that s all thank you all ! :d
bingo!!
bango!!
you got it!!!:d
