I would use TuneEcu and load a tune for your set up. If the only change you have made is adding TORs, you should be OK with the base stock tune. Remove the cat or change the intake, then I would go the TuneEcu route. If you want to do a dyno tune, then PCIII or PCV would be the way to go. Or if you could borrow one do a dyno tune, then load the PCIII map into the TuneEcu tune you are using, then load that to the bike.
