I've got the Dobeck.
Mines the next generation after Canberra's.
No screwdriver needed.
It's all push button.
His instructions were spot on,
mine lives under the seat on top of what use to be the air box.
Very easy to install, plug and play unit.
The instructions aren't very clear ,
but then they don't need to be,
as it's so simple.
3 buttons.
the mode button, the add fuel button, the subtract fuel button.
you've got leds to show you whether you're running rich or lean
in whatever "mode" you're looking to change.
There's a total of 3 modes.
WOT, idle, and cruise,
you can also change the switch points of how fast the fuel
"changes" from one mode to the other.
So a total of 6 modes counting the switch points.
Sounds complicated, but everybody knows,
If I can do it, anybody can.
It really is much simpler than it sounds.
If ya don't like the way it's cruising for instance,
stop, pull over, push the mode button and add or subtract fuel.
Get on and ride it again.
I like mine.
They also offer a veteran discount if that applies.
