Journeyman
Do you recall if the small oil pipe is not touching the lower crankcase cause my Roadster does so
and second, the small oil ring of the oil pipe is not the same as the triumph parts list stock is mentioning (T3600104)
Maybe you did also notice that.
I didn't change the o ring, I realized on reassembly that I hadn't ordered that part.
I'm not quite sure what you mean when you say, "small oil pipe is not touching the lower crankcase." The small oil pipe bolts in by itself at one end and, as I recall, it overlaps and bolts in together with the larger oil pipe at the other end- can only go one way. Do you mean that yours is not joined there, but hanging loose?
I think, and I hope I'm right about that ,as long as the o-ring of the small pipe is ok there should be no oilflow issue for the transmission.
