Lester532
Turbocharged
Need a little help from the Rocket Scientists.
I've been trying to get ride of decel pop since installing triple filters. I've been adding to the F trim at zero throttle between 100-2200 rpm and a little at 1% throttle in the same range. It's gotten better but I still get some loud popping around 1500 rpm. I can control it with just a little throttle or pulling the clutch.
It rums great at all power settings except as mentioned , no flat spots, the idle is okay.
The F and L tables are the same as Hanso's map but I replaced the ignition table with Tripp's K&N underseat ignition tables. This seamed to help with the popping and it runs smoother at lower power settings.
I have a 2005 standard with TORs, CAT eliminator, and triple K&N filters.
Would it help to un-check the O2 sensor ?
I've attached the current map I'm using.
