30 PSI underinflated
Perhaps 30 isn't underinflated, by much. 32-34, as I recall, is called for on the cagers I've had, excluding my Silverado which is 36. I''ve the understanding that overinflating a passenger car tire will produce a crown in the center and thus causing greater center contact. The soft appearance of radials, bulging sides, may and may not be indicative of underinflation for the application. But equating a tractor tire inflation with high speed in the twisties
that's funny. Oh, I'm sorry that was a Tracker. On the otherhand, same difference. 60# in your F350, save yourself some bucks and carve yourself some Flinstone Tires. Fords have always been a tough ride.
With the car tire application on a Rocket this increased center crown patch could be the crowning achievement in going over to the dark side.
Many have faulted the underinflation of the ME880 with quicker wear; personally I'd welcome more outter surface use, versus the inner most 2 inches. Did I hear Triumph and Metzler were in bed on the ME880 Rocket application. Why wouldn't they (name withheld to protect the guilty) hope for 5k change intervals. And with two up riding there is said to be more experiences of bottoming out. I disagree that it's the tire underinflation that is the cause; but, I can be influenced. Is the spring in your step from too much weight in the saddle or being too light in the loafers. Or is it the bench pressing that has beefed up your springs.
I submit, crowning out (max inflation) the tire and slacking off on the bench presses (lighten up the springs) would produce admirable results. Admittedly, riding two up may require adjustments.
That Yokohama looks **** good.:bch: And the stats/ratings on this tire versus the most oft. preferred Eagle is much better. Plus, I believe the AVS100 is all-weather rated while the Eagle is only summer rated.
Now, if Bridgestone would come out with their DTC (dual tread compound) tire for the RocketIII I'd be most inclined. The DTC had a center section that IS substantially more wear resistant. I got an average of 5k more out them than the Metzlers I'd swapped over from, on other bikes. The Battlax BT002, one of several, is a Street Racing tire with the DTC.
Waiting...
