Gregger
Just follow the spark plug wires back to the 3 coils. Note there are 2 plugs per coil. At the coil you will also see the 2 colored primary coil wires plugged into them. Tighten those female bayonet fasteners. 2 are on the right hand side just under the fuel tank attached to the upper frame rail and 1 (very hard to get to) as far forward as possible where the upper frame rails meet the steering head. The easiest way to get to these is to raise the fuel tank for the 2 on the side. I have been able to get to the front coil also from here but it is a lot easier if you remove the 2 plastic covers at the steering head just ahead of the fuel tank. Sometimes removing the 2 side mounted coils will allow easier access to the front coil also.
