Corbin Seat Key Mount How-to
Bobby K
.060 Over
Lynchburg, VA
Just purchased a Corbin Dual Tour for my 05 Rocket. Only thing I didn't like was the Corbin seat mount, was a 1/4" on one side and a 1/2" on the other side from lining up. After reading others posts, here and elsewear, I decided to attach the factory seat post to the Corbin seat.
1. Drilled out rivets and removed seat post/catch from factory seat.
2. Inserted seat post into latch on bike in correct position. Used twine wrapped around post to hold in position and space it up in up direction. (see photo 2)
3. Apply a soft 1/4" thick layer of plumbers putty (see photo 1) to flat area on Corbin seat. Clean this area well first so putty will stick.
4. Place seat in position on bike, being careful to put it down as straight as possible. Press firmly in middle of drivers seat.
4. Lift seat up and turn over. If everything goes well, there will be impression in putty to show position of seat post. (see photo 3)
5. Remove post from latch on bike and place it in position on putty. Use as guide to drill 2 holes needed. Be careful not to drill any deeper than just enough to go through seat base.
6. Check thickness of putty used for marking seat post. It can indicate how thick a spacer you might need between seat post and seat.
7. Attach seat post to seat. I used pan head phillips sheet metal screws #12 x 1/2", and one 1/4" flat washer each screw to space post away from seat. (see photos 4,5, and 1)
8. Remove Corbin mounts from seat and enjoy! (see photo 6)
Last 3 pics
Last 3 pics for above post...
The stock seat wasn't too bad to me, but it was killing my girl. She likes the Corbin much better, and it feels good to me. If she's happy, I'm happy!
**** good job Sir, you follow the same rule as myself :) when she is happy life is good ;)
I noticed our bikes are the same colour and you have the Union Jack on the side panel exactly the same as I have done :eek: and I thought I was the only one..:D
Bobby I am thinking of getting the corbin seat like the one you have my question is how does the seat attach "the corbin way"(do you have a picture of the original fitment) yours looks way more practical and is there enought meat in the corbin seat pan for the screws to hold securely, thanks in advance
Good touring seat by the look of it ...guessing being Corbin it was pretty expensive. What price you willing to pay for comfort i guess . Likes been said a happy and comfortable passenger mean more riding time. WIN WIN ;)
not suprisingly if bought in the States and shipped to one of our Good mates in the states then forwarded to Auss by them its a lot cheaper than buying locally
