Cooling fan
Oops you are correct my mistake that is a 15A fuse. looked like a 7.5A on my shaky old photo.
Offer is good on the cable, hell i don't even use it much, usually use tuneboy
Thanks so much for the offer mate , hopefully if mine turns up in the time frame they gave me I should just about be ready !
As I said , no good deed goes unpunished and sods law dictates the day you send it will be the same day you will probably end up needing it lol ! I am still tempted to bite the bullet and fit the new sensor anyway , check the integrity of the rest of the system and finally use the tune ecu to reset ! I ran the bike today till hot , unplugged the sensor and tested the resistance , manual I have says it should read between 200 to 400 ohms when hot , I am reading 680 !
Start small and work your way up.
An old carpenter saying, if you can't fix it with a hammer, it must be electrici!
Getting to that coolant sensor gonna require the 10 pounder looks like ! Just changed the bloody oil too .
Just noticed your user pic - blimey lucky fella, I thought Ireland was cool and breezy. .
There are plenty more pics where that came from
Ok great you're getting the hang of the multimeter so. Tune ecu will tell u what the error code is that'll give a clue and u can also check temp reading with it too
Thanks turbo your a star !
Incidently , I too was wondering bout the intro pic. Can you Enlighten us ?
this is my bike in a milder state of tune a few years ago. photoshoot was for a bike & boobs charity calendar that didn't transpire after. Roisin here is a friend of a friend.. now they all think i'm a big perv and that the "calendar" was just an excuse
