Gregger
Triumph recommends an HOAT coolant in the Rocket (Hybid Organic Acid Technology). HOAT coolants are good for 5 years or 150,000 miles. Typically coolants made for the European engines should have this chemical makeup. Some may be compatible with OAT types but I wouldn't chance it. Also, do not assume that the colour of the coolant dictates if it can be mixed with another type. If you are going with a premixed coolant, you don't need any distilled water or extra additives. A 50/50 mix is usually recommended for -37C coverage which is more than enough in California. Also gives good protection against boiling and preventing corrosion in the engine. I run a 60/40 mix since my bike can see temps up to -40C while parked in an unheated shed for the winter. When to change??? when it's warm out so you don't freeze your buns off.
When I change my coolant, I simply remove the rad cap, remove the bolt in the water pump with the washer attached and let the rad drain. There is a small breather plug in the block on the left hand side just above the water pump. Make sure you remove this while filling the block/rad. I filled mine until it started to come out then put the plug back in (watch for the sealing washer). Filled the rad then the overflow tank and ran the bike. The engine will eventually burp any air out draw from the overflow tank while cooling.
Oh, you don't need to replace the sealing washers on the 2 bolts being removed.
