..mine won't start in cold weather either..an 06..the Odyssey 625 didn't help either..I'm currently running an Interstate battery 310 CCA..$70..seems to do the job..I've resigned myself to the fact that when it gets to cold to start..riding season is over..sometimes I point my salamander/torpedo heater at the block from about 5 feet away for 5 or 10 minutes..that helps..I've been advised against running a lighter oil..
Where does the majority of the oil sit when the engine is not running (cold)? Is it in the oil pan (sump) or in the tank? My thinking is maybe an oil pan heater would be better than a coolant heater. As you can see, I am determined to lick this. As I have said before, my riding season is short enough without this making it worse.
it is a dry sump system it is in the tank on the side basically there is very little oil in the block itself they run a dry sump like most racecars do as soon as it hits the bottom it's back to the tank"" the biggest difference I have found is make sure it is in neutral when you shut it down starts a whole lot easier
