Clear indicator lenses
Rodneyjd6
Gold Coast
Rocket 3 roadster
Hi where can i get the clear indicator lenses from to fit the r3r thanks
You could also consider going with LED.
Motorcycle LED Light Bulbs - the easiest version would probably be their 1.8 inch cluster ("GEN180CLUSTER"), specifically the amber pigtail version - GEN-18-A-1156. It has an 1156-style socket on a little pigtail and leaves you with the cluster on a short end of wire. You then either place the cluster loose behind the new clear indicator lenses or (what I'd prefer) glue them in with clear silicone. Should do good things for your indicator brightness and looks (the LED's are 100% clear when not lit, so no orange tone at all in the indicator.)
You'd need to pick up a new indicator relay at either Newbonneville or by all means from Custom Dynamics.
You could also get their model that has integrated tail/brake or driving light in the cluster, but wiring those becomes more work as you need more wires that aren't connected to the indicators as default.
just bought the smoked lens cover from new Bonneville. They also have the clear to. Took two days and $32.00 dollars.
