STS Auto indicator install
Discussion in 'Accessories' started by Pete, Mar 31, 2018.
Tags:
  1. Pete
    Pete Life's a Beach
    Country:
    Australia
    390
    Featured Threads:
    11
    552
    103
    Brisbane Qld
    Ride:
    2011 Roadster
    Installed the STS auto cancel indicator system. Works a treat. Senses speed and direction so turns indicators off on the run.
    When I’m acting my age I have no trouble with the manual off switch but when I’m searching for red line and concentrating on trajectory out of a corner I often forget to cancel until way past a safe distance.
    Installed the black box behind the overflow tank and installed two “o” rings over each switch return spring in the switch assembly to limit the switch throw rather than using the foam disks supplied with the kit.
    001C930E-542F-4E4E-A889-3B436D9BF168.jpeg CA079823-A204-4F85-B294-3CAC2A650EE9.jpeg DA66C72E-7E1C-46C7-9A5A-AD80721ED39B.jpeg 28286679-82D5-4644-BF21-B756E235F4A5.jpeg
  2. barbagris
    barbagris Mad Scientist
    12,107
    Featured Threads:
    57
    Media:
    85
    12,556
    823
    On the verge of insanity
    Ride:
    2009 R3-Standard - 1979 Guzzi V1000G5
    Can we get a close up shot of that Pete?
  3. Pete
    Pete Life's a Beach
    Country:
    Australia
    390
    Featured Threads:
    11
    552
    103
    Brisbane Qld
    Ride:
    2011 Roadster
    Ok
    The STS kit allows for a selection of two foam pad sizes and if your nervous about opening a Pandora’s box of springs and ball bearings the pads can be inserted into the back of the switch block with a bit of patience. The thinner of the two foam sizes is equivalent to the two “o” rings I installed per side.
    I opened Pandora’s box and spent the best part of an hour finding the bits that escaped. If you attempt this I suggest you unclip the lid and remove slowly holding the lid parallel to the switch box. If you do as I did and lift one side first it allows springs to release unevenly.
    The switch block has two internal siding blocks each with a captured spring at the end to move the block back to the centre. The foam insert stops the spring compressing fully and prevents the switch mechanism from latching. I used dialectic grease during assembly of the switch block to slow the springs behaviour.
    B8FBDBEF-9540-4E28-98E1-56EC20C9EE67.jpeg 16DDD8EB-DEE3-4CE0-A986-18ED2F8B4080.jpeg 2126B870-AE21-44B6-8075-D4DE9A04EB3B.jpeg 03DF821A-C75B-4463-ADDE-B8AE19E36DBD.jpeg 19CCF35B-7A8A-43F0-9E7B-D1A0CE2F4407.jpeg
    Mittzy and barbagris like this.
  4. scot in exile
    scot in exile Living Legend
    Country:
    United States
    8,648
    Featured Threads:
    201
    11,541
    823
    Fort walton Beach FL, Glenrothes Fife
    Ride:
    2005std, 2011 Carp Roadster, 2001 Tri Adventurer,
    Is that the bracket for the bearclaw that you used? nice write up it looks good.Now use it more as a back-up device as is always turn off your signals yourself.
  5. 1K9
    1K9 Big Cruisers 4 Me
    Country:
    United States
    3,361
    Featured Threads:
    2
    Media:
    16
    3,823
    823
    Clear Lake / Houston, Texas
    Ride:
    2007 Rocket III
    Would there be a way to make motorcycle mirrors with blind spot warning? For some stupid reason people like to hang out in this spot. Most people don't even know what the "blind spot" is or that they are putting your life in danger if they sit there where one can't see them. They think "I'm in my lane duuuuu" If you invade their lane they are quick to honk but by no means stay off another car's blind spot.
    CrzystghndKC and Ishrub like this.
  6. Pete
    Pete Life's a Beach
    Country:
    Australia
    390
    Featured Threads:
    11
    552
    103
    Brisbane Qld
    Ride:
    2011 Roadster
    Not the bear claw
    I fitted a right angle .5mm sheet metal bracket to the top mounting bolt for the over flow bottle.
  7. Plow Horse
    Plow Horse .020 Over
    Country:
    United States
    35
    Featured Threads:
    5
    Media:
    7
    79
    28
    Newport Beach, CA
    Ride:
    2017 Rocket III Roadster
    Pete what did you use for the switched power source?
  8. CrzystghndKC
    CrzystghndKC Triumph guy happy he didn't work for Harley.
    Country:
    United States
    686
    Featured Threads:
    8
    1,191
    103
    Kansas City Mo.
    Ride:
    Triumph: 2005 & 2011 R3 Roadster
    I thought I read the new Goldwings had a blind spot alert like a car. Maybe just discussed.
  9. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    21,950
    Featured Threads:
    114
    Media:
    5
    19,411
    823
    Tacoma, WA
    Ride:
    2012 R3R "Kong" - 2011 R3R "YurMama"
    I use my neck. :p
    Just sayin' . . . :D
  10. CrzystghndKC
    Country:
    United States
    686
    Featured Threads:
    8
    1,191
    103
    Kansas City Mo.
    Ride:
    Sometimes I see cars coming up behind me in my rear view get in my blind spot and then just sit there. I wonder sometimes if their just seeing what kind of bike I'm on. Rockets are rare in heartland.
    Joesmoe and 1olbull like this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
