RocketmanBristol
- Joined
- Jul 23, 2017
- Messages
- 427
- Ride
- 2004 Rocket 3
Purchased a few Rocket/Carpenter parts from a chap who had been left them by a friend who had passed away. Most of the parts are fairly obvious as to what they are/do but would like a little help identifying the cams and valve gear please.
First off there are 6 Valves measuring 37.85 mm (1.490.5")
12 x Shim under buckets with Double springs, retainers and collets.
Two Camchain tensioner blades both Triumph parts 1142048 and 1142055
1 x APE manual tensioner with alloy spacer type thing!
Two Cams which I believe to be Carpenter only markings are 2323 514BC-3 EX. 05-2012 514BC1- I. 08-2011
Along with these parts were the Carpenter Exhaust system and a PCV and set of CP X100A Pistons. I've tried to purchase the head but the seller never got back to me..........so I'd be interested to know what the cams and valves are, and if they would work/worth installing with a standard head? Looking forwards to hearing from the Carpenter guys!
