albertaduke
former airline pilot without the big bucks
kaleden
2021 rocket3 GT
having lost the two brackets originally sent to me by skip I had to have two made up this week for $140 taxes included. I slip them over the bottom eyelets and run the pin through then I can put the bike lift dead center on and the bike goes up steady and level
if any of you R3 classic, or roadster interested here are the measurements
height 65 mm width of plate 57mm hole diameter 13mm (may be different on some bikes) space between vertical plates 17mm ( important ) both plates . upper part of plate above ring 3mm the pins are made with a cut steel rod and slipped through both side appears similar but a grinding tool helped smoothing some edges..and widen the space between plates
bike and me were at the triumph rat rally in nelson BC weekend of 20 th of july that pic was on the road between Kaslo and New denver
