So.... got my new exhaust installed... very sweet. Had a fellow captain help me out loading a tuneecu file (tune number 20050TOR_Dyno.hex) runs much better than with the triumph tors tune. My problems.
tune info : Triumph Rocket III All years Triumph off road pipes and Triumph cat box eliminator Dyno result was 157ftlb and 145hp Full power in all gears, speedo corrected.
1) when i first fire it up in the morning it fire's then dies. Fires then dies. I have to use the throttle lock to keep it bumped up a tad so it won’t die)
2) When cruising 35 mph it hiccup’s and bucks forwards and backwards. Mostly 3rd gear and when slightly downhill.
3) There is an off idle dead spot that makes it very interesting coming out of corners. best way to describe it is similar to a two stroke power band.
4) idle is very eratic and loppy like it's cammed out. very low aswell.
I'd be trying a different tune first. Can't really help you much more than that as to which one to go for but sounds like it's running lean in the lower end.
Had it into the shop saturday. was told that it was an adjustment issue. adjusted the tps, cleaned the crank angle sensor on the bottom, balanced the throttle bodies, reset the adaptives all of that was done. ran "ok" till the next day when it just started surging and wont stay running when it's cold.
Three things
1)try cleaning the crank angle sensor
2) what exhaust are you running
3) send me your e-mail in a pm and I'll send you a couple of good relieable TuneECU tunes
one last thing did you follow the full procedure including reseting the adaptive after you downloaded the tune
Double checking..
I would be hooking the Battery up to a Tender, plugging the Laptop into Mains Supply
and following the Video below ..I would try another suitable Tune
