Hi everybody,
I have a problem with my Roadster 2010, and would like to ask if someone else has experienced something similar.
When I ride the bike, each time I open the throttle or close it, the body of the bike makes a twist. I don't know if it is caused from the engine or from the framework. It is not to much but is a bit unpleasant especially when I open the throttle in turns. When cruising everything is OK till I don't need to open or close the throttle.
When I am not in gear or I'm holding the clutch and rev the engine there is no shake or twist.
When I start the engine and switch to first gear if in neutral the bike sometimes shakes during the switching after that the engine runs smooth but again when I release the clutch to go It starts off with a bit of twist and so on each time I release or apply throttle for shifting.
I would appreciate if someone could share some suggestions.
