Factory manual calls for torque of 60 nm for filler plug - sounds high. Any suggestions?? Also - are compression washers required - mine had none.
Thank you.
Seems a little high, doesn't it? Just remember to do the proper conversion to ft-lbs and don't set your wrench inappropriately.
60 nm = 44.2 ft-lbs
The drain bolt is the one that everyone strips. The manual only calls for 15 nm.
15 nm = 11 ft.lbs <<<====== !!!!!!!! :eek:
