captain jack
Turbocharged
some of the longer lasting members here may remember the issue I have been having with bad starting. Having tried all things including new batteries, I decided 2 weeks ago to remove the starter motor in the beliefs that it was faulty. Having managed to remove it after a lot of hitting, the trouble was revealed. The corrosion on mating faces of motor & engine block was unbelievable, after spending just a few minutes checking solenoid contacts & cleaning it all up & spreading a little Vaseline around, it was replaced and it has fired up every time since. Previously it was failing to start every one out of three attempts. If you have starting problems & run out of ideas, try the starter motor for lousy earth.
