Grendel
.040 Over
hi
took another look at your picture and it looks like some one removed the fuse and tried to bypass it with that blue connector. i don't believe that connecter will handle the current. as a matter of fact that might be your problem.
to start at the beginning these r3's had a problem with the headlights causing problems like ignition switch going bad,bad fuses,and spreading the terminals (because of the heat) where the fuses connect.
judging by that blue connecter they did not know what they where doing IF that is the way they by passed that fuse.
why don't you try to put a 20 amp fuse into that space then see if lights come on when the key is turned on and try to start.
try to get a better picture of where the wires go from the blue connector.
herman
Thanks for taking a look and offering suggestions! I actually stopped and picked up some 20A fuses last night on my way home and thought I would see if there was a bad fuse. I looked at my fusebox cover and according to it's layout, my headlight fuse is the one on the top left next to the 30A fuses and the one that is empty is marked as empty. I don't know why my fusebox layout would be different, but that is what it says.
I had a brain fart too. I MEANT to pop a fuse into the empty slot just to see if it made a difference and I forgot. I guess when I saw the "empty" label the thought just flew out of my head, lol.
