Wajhi
.060 Over
Hmm, I'm no expert, I just share my experience and try to help folks move forward until the calvary shows up. ;^)
1. These TuneECU maps are not meant to be used with PCV. You indicated it was connected and had a map loaded with Clavigers tune. Maybe disconnect PCV and try his again.
2. Are you doing the ISCV reset and 12 minute tune (12 minutes AFTER the fan first kicks on)? It will take the ECU awhile to get acquainted with a new tune.
3. O2 sensor needs to be OFF or it will be fighting the maps settings at lower speeds - double click and remove checkmark or right click and select disable before downloading.
As per Claviger wrt O2 sensor removal and bung hole plug:
First off, why it's best to remove it: They are a sensitive device, the temperature is controlled to be in a narrow window for max life span, moisture is the devil for O2 sensors and it's disabled in software and left in the bike moisture can kill it.
Second, as to why it's better turned off: Triumph tunes only use it at low RPM low opening, and they shoot for a 14.3ish AFR, nothing wrong with that to be honest. Read on how narrow and sensors work, they don't measure the afr, they count how many " too rich" or "too lean" incidents it has over a time span and add or remove fuel to compensate. The result is an engine that's never right, instead it swings back and forth across the target lean to rich, but never right.
The range of the swing depends upon how fast the ECU updates the sensor value and does the man. The rocket ECU does both sampling and math pretty slowly, the result is a chunk chunk chunk idle, when you turn it off and set the AFR slightly "too rich" in the mid to high 13:1 range idle will be dead steady and stable.
Additionally if you were to make changes in your F and L tables, and the sensor is turned on but you don't change the AFR target to deactivate closed loop, it'll slowly trim both short and long term trims. The problem with that is that those trims are not limited to the closed loop areas but are instead applied elsewhere in the map too. It effectively undoes any custom ECU work you have.
Add in a PC-V and then there's another layer of computer fighting the ECU which is already fighting the work you've done.
So please treat me as total DUMDUM......and here what I got from this message as an action plan for me:
1. The O2 sensor has to be disabled in both the maps i.e. Claviger one and HAnso one.......when I open the maps in Tune ECU, Claviger has Q2 checked and Hanso one has it unchecked......So for any of these map my first action should be to disable that option, right?
2. secondly, yes my PCV is connected with zero values all over, so you are saying disconnect the PCV all together i.e. unplug it from the main harness, then plug the O2 sensor eliminator that is inside the right cover?????
3. after that, I would have to unplug the O2 sensor from the main exhaust pipe that is after the header and before the TORs....if I I do that then where do I get the plug for filling that gap?
and yes I was doing the ECU 12 minutes tune...however I forgot to reset adaptation for Claviger one but did do that for Hans map.....
it will be great if someone through in the picture of the O2 sensor that needs to be taken out and the plug that needs to go in its place, please????
