2014 rocket touring brake light stuck on any suggestions?
Bill
2014 rocket 3 tourin
2014 rocket touring with 4700kms and now my brake light is stuck on,doesnt matter if the engine is hot or cold,also does anyone know how to change the tail light bulb?Thanks in advance
No ideas on brake light switch. Try spraying it with a good cleaner. To change the bulb just reach up under the fender to tail light and twist and pull bulb out.
Which is sticking at lever or foot pedal?
Neither the pedal or the lever is sticking,they are both working freely,but the brake light stays on whenever the key is on,must be a short somewhere.
Thank you for the help.
It could be a short or possibly a faulty hydraulic pressure switch. Either way unplugging the wires at the switch, as suggested, will identify whether it is the front or rear brake. A 2014 bike should be under warranty? Where in Ontario are you?
Yes it is under warranty.I am located near London,Ontario.
