2008 touring engine died and turns over but wont run!?
Just a thought for you to try if all checks out ok I had a problem with a TPS haveing a bad spot which while the test said it was alright, but with mottor running and TuneECU hooked up the TPS voltage became erratic at the same place as bike was misfiring. Also while searching for problem I found that my injectors were partially blocked by crap that had gotten thru filter
