Normen
- Joined
- Apr 1, 2021
- Messages
- 22
- Ride
- Rocket 3 GT
There are 2 green cables - one of them comes from the accessory-relay.
Be sure to use the correct one - i think the other one is for abs
to choose the right one check the following:
1. Turn your rocket off -> check: cable should not have any voltage
2. Turn ignition on -> check: cable should have 12-14V
3. Turn ignition on + take out the accessory fuse -> check: cable should not have any voltage
4. Turn ignition+engine on, connect a mobile phone to the usb under the seat and check that its loading
5. Turn ignition+engine on while loading mobile phone -> cut the green cable -> check: mobile doesn't load anymore
For 1-4: you can pierce a needle in the cable - no need to cut it
Maybe a little bit paranoic - but i want to get sure
