bigern2300
.060 Over
As i reported the other day, back months ago the dealer replaced the center coil which had supposedly died causing the center cylinder to cut out. Well, the other day i was out riding when the center cylinder started cutting out again. I thought hell no...no way i could be losing another coil on the same cylinder. Got home and raised the tank and started wiggling wires with the engine running. Lo and behold, when i wiggled the power wires to the center coil, the cylinder came to life! Closer inspection of the connectors reveiled that they were jampacked full of dirt and grime. Also the female connector had spread and gotten loose. If you look at the 12 volt power connectors to the coils, they are not of the best design...pretty much designed to to capture and contain any dirt or water that happens to fly by. I plan to change out these connectors with somekind of shrinkable, waterpruff connector. Also on these coil power wires, you have to be carefull when removing them...don't just grab them and wiggle them off. If you look in the backside of the connector, they have a small metal release tab in the connector. Bigern
