Wrecka living up to his name breaks sheit again
A couple of oil filters that fit are:
Purolator Pure One PL14612
Mobile M1-108
When you take the final drive off to lube the splines, undo the filler bolt and drain everything out. Then you can re-fill it with fresh oil when you put it back on the bike. This suggestion is for klutz's who break thing easily because the drain bolt will stuff things up if not put back correctly.
If that filter is from your vmax filter post and the threads and psi rating on the spring is the same then you should be ok, just account for the extra volume...
