cootertwo
- Joined
- Mar 24, 2013
- Messages
- 2,043
- Location
- Labelle Florida USA
- Ride
- 2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
Wozers, got some good stuff from Amazon. Will make up a headlight by-pass, among other things. Just whipped me up a Homer simpson Bevertail bypass! Separated the two terminals of the headlight fuse. Now the one side that comes from the ignition switch, goes to one side of the closing relay coil, other side of that coil is grounded. Other side of headlight fuse, that goes to headlights, is connected to one side of the points in the relay, other side of those points goes straight to battery. All fused too. And YES, the headlights are quite a bit brighter! Wiring loom and tidying up later.
10 Pack - EPAuto 12V Car Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder
5 Pack - EPAuto 30/40 AMP Relay Harness Spdt 12V Bosch Style
Wang-Data Black Split Loom Braided Cable Sleeve 1/2 inch X 20ft (1/2" X 20')
Permatex 22058 Dielectric Tune-Up Grease, 3 oz. Tube
