Wireless remote ignition
will the bike still shut down with the kill switch
Yes, all systems still work as designed. Kill switch, kickstand, etc. HOWEVER if you turn kill switch to run position the power is automatically restored but you will have to press start button to crank engine .
Not in photobucket as a package, I just have my pics stored there.
Hey Scot, show me how cause I sure couldn't get the tank up without doing the rear bolt.:confused::confused:
On mine, I loosen the gauges and lay them forward. When lifting the tank, slide a finger or two under the chrome tang and lift it up firmly more or less pressing it up and back towards the tank. This will allow for sufficient clearance to work the tank up without having to remove the rear bolt.
I figured this out after lowering the tank after another install and the chrome tang was pushed up by the gauge mount and it slipped on by. Reversing this situation allowed me to lift the tank.
Just got my EB headlight relays and pc-8 fuse block. Also doing Keyless ignition and removing key switch and installing power outlet in its place.
I almost went Hillbilly on her with a chunk of 4x4 and a pry bar.:D
