Morph1976
.060 Over
Rocket 3 tourer 07
Hi guys back again for advice. My engine and electrics totally shut down when riding. Managed to get lights working but dash doesn’t light and won’t turnover. It has a keyless ignition wired in and I’m guessing I have a loose wire. Does anyone know what colour the ignition wire is so I can try to fix it. The last couple of days I’ve had a couple of issues when pressing the start button, I’ve had to press it a couple of times to get it to register but the dash has never failed before. Thanks in advance
Sounds like a main power connection. Check main battery wires and clean.
Some those keyless systems you can just disconnect the wire from system then plug the wires back together to eliminate the keyless system.
You can take a 12volt test light/volt meter with neg wire to neg bat and probe each side of fuse to see if both sides have 12 volts (there are two spares at the back ) then the main ign wire may be bad
Give us some voltage reading starting with bat bolts then on bat connectors then at starter solenoid where the main bat wire connects
This should get you started
Hth
