windshield.
They should bolt 2014 to 2014 since all engines are the same I believe a 2014 touring will bolt to the 2010 to 2013 roadster unless the rail locations and hole sizes have changed
Thank you for the response.
A ray of HOPE?
I am just a tad concerned; however, about your use of the word "unless".
A ray of HOPE?
My guess would be based on the fact the no matter what year Roadsters they have since ABS was added nothing else has been changed or they would not be having so many problems. So other then addig ABS to the touring which could also be just adding the rear engine unit, the wheel sensors and brakes and brake line sh*t plus updating the software in the ecu they are the same.
I researched the fische and found no common part numbers.
Seems one would have to change out the entire assemblies including master cylinder and controls.
WAY expensive - as you have said!
Thanks!
Sorry about the back, Bro; I feel for you!
2014 Roadster and 2014 Touring complete foot rail assembly will swap out... Spent an hour looking at both bikes side by side.
