My recommendation is quit the little junk and get real power. Neville Lush or Carpenter parts for a motor build. You won’t have to wonder if it was worth it. Does a stock Rocket need more power no and yes. No, it will go plenty fast and yes it can be absolutely scary awesome.
If you are looking for a cheap way to get a bit more bang down low look at a gi-pro with atre by a company called heal tech it's pretty much plug and play and acts as a gear indicator but most importantly it tricks the bike into thinking it's in 4th when it's in 1st 2nd and 3rd gear so you override the retarded ignition timing and get full power
Not really but you can get the ignition timing changed in those gears with tune ecu also there are maps available with it already done in addition to secondary butterfly's open 100%
Opinions are welcome on this thread, but it must be your own. Do not attempt to legitimize your opinion via some other writing, law, teaching, similar event, or source of information.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register. By continuing to use this site, you are consenting to our use of cookies.
