Which Tune ECU tune for '05 with Jardines?
ICTRocket
Wichita, KS
I have an '05 with Jardines. What tune is correct?
20228 says "aftermarket silencers with out catalyst"
20226 says "aftermarket silencers with catbox removed"
Both seem correct for my Rocket.
The closest is 20226 but this is still probably too lean for the Jardines.
Thanks for the tip. I did install a pair of Smartpartz quiet baffles in the Jardines. It helped a lot with the excessive noise and reduced the decel popping a good deal as well. I'll try 20226 and see how it does.
Tripp,
I've had the tune you recommended installed for a bit, and the Rocket runs beautifully with it. Prior to the new tune it would surge, hesitate, had a lot of decel popping, and even the occasional backfire through the intake. Now it idles smoothly, pulls strong when on the throttle, cruises perfectly, and only a slight burble during decel. Thanks a lot for the tune. I'm really happy with the way the bike runs now.
jb
