martym52
You hit the nail on the head with questionable mechanic. I had the guy install Neville’s street cam a year ago and he screwed up everything he touched. He was recommended as the go to guy by my local dealer. His name is Eric Colvin and is in Oklahoma City. It was running ok before I took it apart, maybe some valve train noise but hard to say, my ears are bad with higher frequencies. It dyno’d around 160 hp & torque. I have watched the videos of how to use a feeler gauge and am not quite the amateur I painted myself to be. I believe I got the clearances pretty close. It was tight quarters as you know and I was using a 1/2”x3 1/4” go/no go feeler gauge which was difficult to work with in that space. I did them all 3 times over looking for a consistent number. I’m going for a different feeler gauge and doing it over to see if I get consistent results, any recommendations on a better feeler gauge? It looks like Im going to need an assload of shims, where is the best place to get them?
You should be able to get .004", .006", and .008" long type feeler gauges at your local NAPA store. Shim kits are available, but pricey from BikeBandit. You could set up a shim-share for forum members, (hint-hint) LOL
