Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
After sorting through some issues with certain tunes, i have compiled my own Hybrid tune.
First things first, it is a composite tune using various bits from various tunes to achieve what I am after, that being a very smooth ride at low throttle openings, no herky-jerky crap, but a butt load of power from 50% throttle and up. That being done with the O2 sensor disabled and unplugged. I don't like ECUs ****ing up my hard work doing maps, and I live in a place that the weather is the same pretty much everyday.... Mission already accomplished
Cruising around doing the same speeds as cars AFRs stay in the high 14s, sometimes 15.1:1 - 15.3:1, perfectly fine for low load cruising. Even accelerating like a "normal" person, about the same rate as the family mini-van, it stays in the mid-high 14s, perfect. Went hill climbing a bit to test out the higher load areas in the same RPMs (also drag back brake to increase load), and it dips down into the mid 13s, again, perfect behavior.
Testing out the reactions to snapping open the throttle from 2k-3k areas, and it does a split second (.08 of a second to be exact) lean (normal behavior on snap WOT), then drops down into the 12:1 range. This is where things get kind of weird...
3rd Gear WOT pulls - when it drops to 12:1 it dips further into the 11:8:1 area and stays there until redline.
4/5 Gear WOT pulls - It doesn't drop to 12:1, it drops to like 13.2:1, and floats in the mid-high 13:1 area until at least 5k (cant run out 4th/5th here on Oahu).
What I am not understanding is why 3rd gear is dipping so low and staying there, yet 4th and 5th are spot on. It seems like the ECU has a "hidden" enrichment factor for the lower gears that isn't documented anywhere. Bike still rips 1-3 gears just fine, actually got a CBR to run from 35 mph on the freeway while logging today.....lols just fing lols.
Suggestions?
I have attached a link to where you can get my tune to this post. DO NOT INSTALL THIS TUNE ON A PRE-2013 ROCKET, it is based on tune 20773 which will only work on CAN enabled rockets using the new ECU configuration.
http://www.r3owners.net/threads/tune-for-a-stock-r3-developed-on-a-roadster.20552/
Suggestions?
