Spent time on dyno and no matter setting still backfired around 2200 rpm. Not popping but big bangs.If you have a pc5 and AT there really is no need to hunt tunes. You have the tools needed to dial in the tune to your bike perfectly already.
The popping and burbling is almost certainly a lean condition on over run when decelerating. You are hearing it more now because the crossover is open and doesn't mask the sound.
The popping on deceleration after a wot pull is not in any way bad for the bike. If it bothers you add fuel to the 0% throttle column above 2k rpm area until it stops.
Factory tunes purposely are set lean there because fuel there is all wasted fuel, so they cut it for both emissions and mileage purposes.
So stock filters if tune for 3 k&n not culprit?
