Journeyman
It's the newest version. I reinstalled the software today in case the previous had somehow become corrupted, including the driver for the cable. I know a computer with a newer operating system might be a solution, but I'm puzzled as to why it worked before. Finding someone with another PC laptop is difficult. Just hoping someone has seen that error before (doesn't necessarily look specific to TuneEcu) and knows what the fix might be. Thanks
It's a Toshiba Satellite A205-S5803. The sticker says Dual-core processor T2330, 1024MB PC5300 DDR2 SDRAM, 120GB (5400 RPM) HDD.....
I found an install disk. If I go that route is it as easy as putting in the CD and following directions? Sounds like you might be a Mac user too and can "feel my pain."
She is running great at the moment, so I'm not desperate to get this going immediately, but would like to experiment with some different tunes beyond the 20355 at some point. Still mystified as to how it worked before and I was able to install the 20355 map a couple of months ago. The program sees the bike, just won't let me save or load new maps.
Thanks again...
Here's the error code in detail:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method not found: 'Void System.Windows.Forms.FileDialog.set_AutoUpgradeEnabled(Boolean)'.
at TuneECU.ISOMain.UpgradeEnabled(mOpenFileDialog sender, Boolean save)
at TuneECU.ISOMain.openMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1003 (QFEN-2.050727-1000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
TuneECU
Assembly Version: 2.5.8.0
Win32 Version: 2.5.8
CodeBase: file:///C:/Users/Blake/Desktop/Tune%20ECU/TuneECU%20v2.5.8/TuneECU.exe
Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
TuneLibrary
Assembly Version: 2.5.8.9
Win32 Version: 2.5.8.9
CodeBase: file:///C:/Users/Blake/Desktop/Tune%20ECU/TuneECU%20v2.5.8/TuneLibrary.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
