tdragger
Looking for a knowledgeable wrench out there to translate the following TuneBoy instructions to TuneECU equivalents.
I need to replace my primary TPS tonight and don't want to screw it up.
Originally Posted by idk
1. Connect your computer to your bike and open TuneBoy (not TuneEdit)
2. Turn on the ignition - do not start the engine
3. Click on "Sensors". On the second column, 2nd from the top, you will see "TPS volts". That is the information that you will be adjusting.
4. Click ONCE on "Reset ISCV", which is on the bottom left hand side. This will cause the bike to make a little noise and the "TPS volts" will change. A scrolling text of information will appear at the bottom of the TuneBoy screen which will give you the instructions from here on. Follow them exactly.
5. To adjust the TPS you will need a torx socket wrench (I can't remember what size, but it is the 3rd smallest one in my set) and a very small (3/16, from memory) ring spanner (box wrench) to fit around the hex part of the torx socket.
6. Fit the ring spanner over the torx socket and hold the socket into the torx bolt with a finger from your right hand. Use the spanner with your left hand to turn the torx socket. (This is different from the manual. The manual suggests that you take the throttle bodies off to make this adjustment. Somebody designed the throttle bodies to be too close to the frame to allow access to the TPS bolt. If you can get the right sized Metric hex or Allen bolt to replace the torx bolt then now may be a good time to do it.
7. Loosen the torx bolt and adjust the TPS by twisting it
8. Re-tighten the torx bolt and check to see that the reading is still correct
9. If the throttle adjustment (2nd adjustment in the instructions scrolling along the bottom) needs adjusting then you will need a 7mm ring spanner to adjust it with. (You will probably find that that area has a lot of dirt and oil build-up. Spray it with WD40 to clean it. This should probably be done before you start the project.)
10. Follow the rest of the scrolling instructions. When it tells you to do nothing, do nothing. After completing everything then turn the bike off.
11. Start the bike. It will probably rev high for a few seconds then drop back to normal idle. You can do a 12 minute tune if you want, but it's not necessary.
It took longer to write this than do it.
