Leif Almberg
.060 Over
Using a table like this one as a template recommended by Tuneboy for Air/Fuel-Ratio impovements
do you think this might be a good table for the Roadster?
12.80 is known as the best ratio and I have leaned it in small steps depending on TP.
the same ratio for all RPM is an idea from the Tuneboy table.
this is of course depending on the ECU trying to achieve this ratio, which it does not do all the time. richen the fuel in the F1-F3 tables may be needed as well, but that is hard without a lambda to see the result.
am I right, or way off?
