HeR3tic
No. The pipes aren't drawing any air that will make an effect in the realm of decel popping. The popping and farting originates well before the final pipes come into play. The colder air intake, on the front side, will of course make a power increase difference. I'm about 600 ASL. I was running the same tune as you mention for quite some time. Worked great! And I don't run TORs. I have a "silencer upgrade" and a TuneBoy and I wouldN'T trade the works for immortality
I just loaded 20050_3Decel, with a tweak or two. I've not test ridden yet, it's gotten dark and the Trick or Treaters are banging at the door. We'll see in a week whether there is a MPG drop.
As for larger pipes, I've an opinion that will surely get loud rebuttal: The single most restrictive aspect of the stock exhaust is the manifold prior to the cat box. Then the cat box, and then maybe OEM exhaust muffs though the combined outlet of the most restrictive silencers, ie., my standard pipes, is larger than the three into one exhaust maifold restriction. Granted that with larger combined final gas outlet, with TORs, there is a volume increase and a resultant speed increase but until someone can demonstrate an appreciable benefit I'm sticking with my theory. Frankly, NASCAR could institute a dBZ noise max and THEN I might go to the races. Until then I watch the races on TV. Headers are the only answer but they don't have to give you a head ache.
I have another theory about under tanks filters, but there's already enough controversy for one post.
