Anything else you did? Unless you just have bolt on stuff just do a tune ecu upload with a proper map. Ram intake with removed secondaries, full cat delete and cobra pipes is my setup and the rabbit hole I went down is there A: have your trans built out with undercuta and beefy dogs and have carpenter do a build or just bolt on a few things and diy tune ecu. The OBDII plug in performance stuff is worthless. The bolt on stuff is as much power as you can get without internals.
Also the transmission is a mess. So unless you put a few bucks into it just bolt on and done.
