It looks like the touring screen which is 6" taller than stock. I'm 6'3". With the standard screen in place the wind hits me just above my eyebrows. The touring screen puts it mostly over my head. I can feel a little on the top of the helmet, but no buffeting. They are two of the best windshields I have ever used. The tall one changes the look of the bike a little because it's more dramatic.
The lights look like the driving light kit. I installed one on mine. Make sure you have all the parts before you begin. Some of the light kits have been shipped with one wire harness missing. (Mine was) Install takes a couple of hours if you take your time. The harness just plugs in under the tank. BTW, the instructions with the kit suggest you turn the switch on and test the lights prior to lowering the tank. If you do, it will trip the check engine light because the cluster is unplugged. It will go out on it's own after three heat cycles.
I'm interested in the GPS, radar detector mounts. What did you use, ram mounts? How did you power it?
thanks.
