Triple K&N Mod
John's right. Those filters are bathed in pure naked heat.
Just playing around with the idle while the engine was running would scortch my hand w/o a glove. The filter I use to protect the air temp sensor is bathed in heat, and too hot to touch :?
Gains to be had here...
flters
Ha, these are hot too! Because of the tripod you get a sprial spinning induction.
rockenrobert
gotta see the world, it will only take a mintue
Link Removed
k/n
hhhmmmm..... using ole "smiley face " ta make a point!!---clever!!! and all the while summit racing keeps selling $$$$$$$ of cold air intake units !!!!! betcha them boys are smilin!!!---john
Re: k/n
john l. mckee said:
jolly----longer, bigger filter is good idea. gets you out in cooler air. elbow at bottom is not! air must turn to get into t.b. bore! every turn loses you air. you lose what you gained. solid filter top is no help. go w/ x stream k&n w/ filter on top. now IT'S out in coolest air ya gonna get! -----here is a good example of filter " under " bearclaw. take a blanket and electric fan outside in full sun.----cut fan on hi. now you get in front of fan and under blanket. THAT's filter under bearclaw. now stick just your hand out from under blanket. cooler ain't it!! your hand IS FILTER OUT IN COOLER AIR!!!! jeez boys.--this ain't rocket science!!!-----------john ---------------------------------note--i used piece between motor and t.b.'s to kick filters out.(stock makes turn too) not filter. my flow from top of filter to head is in a straight line-no turns.
John, the only reason i opted for the angled flange was that because they are quite large you can to a certain degree use the angle to move them out of the way of your leg.
