warp9.9
Pocałuj mnie w dupę
Yes you will need something else besides the PCV unit. Even though it can except a 5 volt signal you could use for a fueling dump on when in NOS mode. But you will still need to adjust the timing especially when the NOS is on. Unless your wanting to change your pistons also !!! When NOS is not set up correctly you are riding on a BOMB
If your planning on a Kit from Bob then you might as well get TUNE BOY as you will need it for their high rpm map.
