Nuclear Boss
Standard Bore
So my 2006 Rocket 3 with about 15k miles has been having this very annoying problem more frequently. When decelerate or coast, it seems to miss several beats, causing "lurching." when I accelerate she seems to respond just fine, with smooth power.
Also, to test it when it is acting up, at a stoplight I'll press in the clutch and rev it up to 3000, 4000, 5000, or 6000, and hold the throttle steady, but the RPMs jump all over the place, pausing here and there at different rpms with no rhyme or reason.
About three or four thousand miles ago, I had the common idle problem which resulted in the dealer retuning it with a different map, which didn't work for more than about a week, and then I got my primary throttle position switch replaced. This worked for about two thousand miles and now this new problem.
Any thoughts or experience on this problem? I appreciate it, thanks,
Jeff
Jeff
