Supabrake 3 From Vizi-Tec
Rogiecrockett
Fairfield, IA
2015 Triumph Rocket III Touring
Had one delivered yesterday. Pulled right side cover off and installed it in less than one minute. Did not have to remove seat.
Fits using existing connectors. No cutting or wire taps required.
Easily adjustable to get different flash rates and types.
It is definitely more pricey than other modulators but is more flexible. I am going to add some nonflashing Hyperlites which should really make my rear light up when braking.
Glad I added this to the R3T.
4 wires are routed on the bottom of the rear fender and enter under the right side cover.
The wire being pointed at is the connector needed.
Thanks for the post. I have one just haven't installed it. Glad to hear you like it!
This is what the unit looks like when connected.
Add some di-electric grease if necessary. Zip tie to the frame or elsewhere if needed.
