Stuck in fifth and clunking, -after advice, hints tips and tricks TIA
I've borrowed that (and the bar that goes with it) from the dealer a couple of times. I had planned to take that schematic to a machinist along with a couple of cartons but haven't got around to it yet.
My alternative was to source a bolt that matched pitch and diameter and taper the end to fit...but haven't got around to that either...i have an 11 month old so spare time is a long forgotten luxury...
A 3rd option is order one from Triumph if you are feeling wealthy!
We will take this opportunity to summon @Mittzy and @Ishrub who might know of one on the east coast somewhere...both are resourceful fellas :thumbsup:
I have those tools, BSA Bob had a couple made up and i bought one for $50 AUD
@Noir_Nikko you may find a happy sharer in Brissie then. ;) :whitstling: :cool:
It helps us all if we display our location in our Avatar block.
Click on your Avatar image in TOP RH banner strip and then click on Account details and it will allow you to modify what appears.
Will it make a difference making the alternator removal out of 1 1/2 hex
$100 vs $50
I think I'm going to buy the Clutch Basket tool
By the time postage is paid anyway
Thank you all again and again
Will it make a difference making it out of 1 1/2 hex
$100 vs $50
I assume 1.5 inch is referring to the head size?
...also you can make the clutch basket tool for free if you screw a few fibres and steels together from an old set. Ask your dealer if they've got any lying around. Otherwise I think Suzuki have a couple of models with same size clutch???
I am 👍👍
The alternator removal tool, machinist can make it for $50 if out of 1 1/2 AF Hex
Or $100 if 35.5AF I believe from the drawing
(I think i've answered my own question after getting a chance to read the manual again, it won't matter)
It should only change what tool I use to do and undo it up ie, 1 1/2 Af vs 35.5Af?
Made a tool for the flywheel, however need to modify it now realising the purpose of the alternator puller tool
Worked to get the centre bolt out but not the rotor
Going to make (as per @mr hunt suggestion) or buy the Basket tool
Keep telling myself I will need the tools again in the hopefully distant future 🤞🤞
Annnnd for anyone in Tassie, I have a set lol 🤙🤙
This little spring fell out of the crank case bottom half,
Motor was upside down and it fell out when I turned the case back over for inspection.
Pictured beside non-return valve
Any ideas gentlemen??
Believe it goes in engine block before you install non-return valve, same hole.
It is not #21 Detent Spring T1190086 or #25 Spring, Gearchange Return T1190016
So if it has no broken edges and is neatly finished at each end without protrusions it could be:
#6 Spring, Gear Indicator T1190780
#PartStockRRPQty
Used
Basket
1BOLT,SPRING ABUTMENT
T1190208
No Longer Available
Share this part
NO LONGERAVAILABLE$3.27excl. VAT(£2.63)-
1Bolt, Spring Abutment
T1190054
Share this part
BACKORDERNO STOCK$3.54excl. VAT(£2.85)1QuantityMinusPlus
2Kit, Detent Arm & Spring
T1190307
Share this part
BACKORDERNO STOCK$16.26excl. VAT(£13.09)-QuantityMinusPlus
2Dentent Arm Assy
T1190305
Share this part
3Arm, Gearchange Actuator
T1190061
Share this part
BACKORDERNO STOCK$16.63excl. VAT(£13.39)-QuantityMinusPlus
4Selector Drum
T1190219
Share this part
BACKORDERNO STOCK$209.03excl. VAT(£168.30)-QuantityMinusPlus
4Kit, Selector Drum Assy
T1190640
Share this part
BACKORDERNO STOCK$242.81excl. VAT(£195.50)-QuantityMinusPlus
5SHAFT GEAR POSITION
T1197800
Replaces T1190267
Share this part
BACKORDERNO STOCK$30.09excl. VAT(£24.23)-QuantityMinusPlus
6Spring, Gear Indicator
T1190780
Share this part
BACKORDERNO STOCK$2.86excl. VAT(£2.30)-QuantityMinusPlus
7Pin, Gear Indicator
T1190777
Share this part
BACKORDERNO STOCK$2.96excl. VAT(£2.38)-QuantityMinusPlus
8SHAFT,GEARCHANGE ACTUATOR
T1190212
Share this part
BACKORDERNO STOCK$31.14excl. VAT(£25.07)-QuantityMinusPlus
9Bearing Ball, Unshld, 20x42x8
T3800090
Share this part
BACKORDERNO STOCK$4.22excl. VAT(£3.40)1QuantityMinusPlus
10DETENT WHEEL
T1190004
Share this part
BACKORDERNO STOCK$21.80excl. VAT(£17.55)-QuantityMinusPlus
11Screw, Pan/Hd, Tx, M6 x 25, Enc
T3331041
» Eng No 127359
Share this part
BACKORDERNO STOCK$0.58excl. VAT(£0.47)2QuantityMinusPlus
12Bolt, HHF, Lghtd, M8 x 16, Enc
T3201977
Replaces T3200220
Share this part
1-3IN STOCK$2.84excl. VAT(£2.29)-QuantityMinusPlus
13Keeper Plate
T1190207
Share this part
BACKORDERNO STOCK$11.45excl. VAT(£9.22)1QuantityMinusPlus
14Screw, M6 x 12, Enc, Raw
T3051062
Share this part
BACKORDERNO STOCK$0.83excl. VAT(£0.67)2QuantityMinusPlus
15E Circlip
T3500044
Share this part
1-3IN STOCK$0.53excl. VAT(£0.43)1QuantityMinusPlus
16Selector Shaft
T1190066
THIS PART IS NOW OBSOLETE
Share this part
NO LONGERAVAILABLE$17.04excl. VAT(£13.72)-
17SELECTOR FORK, 1ST/4TH GEAR
T1190650
Share this part
BACKORDERNO STOCK$68.62excl. VAT(£55.25)-QuantityMinusPlus
18SELECTOR FORK, 5TH GEAR
T1190655
Share this part
19SELECTOR FORK, 2ND/3RD GEAR
T1190660
Share this part
20WASHER, THRUST,24X17X1.5
T3550116
Share this part
BACKORDERNO STOCK$3.34excl. VAT(£2.69)-QuantityMinusPlus
21Detent Spring
T1190086
Share this part
BACKORDERNO STOCK$2.74excl. VAT(£2.21)-QuantityMinusPlus
22Gearchange Shaft Assy
T1190028
Share this part
BACKORDERNO STOCK$95.01excl. VAT(£76.50)-QuantityMinusPlus
23E Circlip
T3500044
Share this part
24SLEEVE,SPRING,GEARCHANGE
T1190053
Share this part
BACKORDERNO STOCK$0.89excl. VAT(£0.72)-QuantityMinusPlus
25Spring, Gearchange Return
T1190016
Share this part
BACKORDERNO STOCK$2.70excl. VAT(£2.17)-QuantityMinusPlus
26Washer, Spring, Wavy
T3600908
Share this part
BACKORDERNO STOCK$1.64excl. VAT(£1.32)-QuantityMinusPlus
27PLATE, CONTACT
T1190217
No Longer Available
Share this part
NO LONGERAVAILABLE$6.37excl. VAT(£5.13)-
Wrong type of springs
10Spring, Belleville, 54 x 39 x 0.7
T1180052
Share this part
1-3IN STOCK$4.01excl. VAT(£3.23)-QuantityMinusPlus
10Spring, Belleville, 40.5 x 0.6
T1180288
Share this part
